Introdução
If anyone ever finds themself in need of a new motherboard module on an HP Stream 13 laptop, but cannot afford the costs of a repair technician, then they will find this guide handy and helpful.
O que você precisa
Place the laptop face-down so that the bottom of the laptop is facing up.
Flip the laptop back up so that the HP logo is facing up. Open the laptop so that the screen and keyboard are showing. Insert the jimmy tool to remove the casing around the keyboard/touchpad area. Move the jimmy around the perimeter to loosen the casing. Remove the casing to reveal the guts of the laptop.
Ferramenta utilizada nesse passo:Flathead 1.5 mm Screwdriver$5.49
Unplug the battery cable.
Remove the screws securing the battery in place using the 1.5 flathead screwdriver.
Lift the battery out of the laptop.
