Ir para o conteúdo principal
HP Stream 11-y010nr Screen Replacement
O que você precisa
  1. HP Stream 11-y010nr Screen Replacement, Keyboard: passo 1, imagem 1 %32 HP Stream 11-y010nr Screen Replacement, Keyboard: passo 1, imagem 2 %32 HP Stream 11-y010nr Screen Replacement, Keyboard: passo 1, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr Screen Replacement: passo 2, imagem 1 %32 HP Stream 11-y010nr Screen Replacement: passo 2, imagem 2 %32
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr Screen Replacement: passo 3, imagem 1 %32 HP Stream 11-y010nr Screen Replacement: passo 3, imagem 2 %32
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr Screen Replacement: passo 4, imagem 1 %32
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr Screen Replacement: passo 5, imagem 1 %32 HP Stream 11-y010nr Screen Replacement: passo 5, imagem 2 %32 HP Stream 11-y010nr Screen Replacement: passo 5, imagem 3 %32
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
  6. HP Stream 11-y010nr Screen Replacement, Screen: passo 6, imagem 1 %32 HP Stream 11-y010nr Screen Replacement, Screen: passo 6, imagem 2 %32 HP Stream 11-y010nr Screen Replacement, Screen: passo 6, imagem 3 %32
    • Using your fingers or a spudger, pull the battery cable from its connector to disconnect power from the motherboard.
  7. HP Stream 11-y010nr Screen Replacement: passo 7, imagem 1 %32 HP Stream 11-y010nr Screen Replacement: passo 7, imagem 2 %32
    • Insert iFixit opening picks into the edges of the screen to break the seal between the screen and bezel.
  8. HP Stream 11-y010nr Screen Replacement: passo 8, imagem 1 %32 HP Stream 11-y010nr Screen Replacement: passo 8, imagem 2 %32 HP Stream 11-y010nr Screen Replacement: passo 8, imagem 3 %32
    • Peel the hinge up by sliding iFixit opening picks left to right along the hinge.
  9. HP Stream 11-y010nr Screen Replacement: passo 9, imagem 1 %32 HP Stream 11-y010nr Screen Replacement: passo 9, imagem 2 %32 HP Stream 11-y010nr Screen Replacement: passo 9, imagem 3 %32
    • Remove the bezel by pulling upwards on the left bottom corner.
  10. HP Stream 11-y010nr Screen Replacement: passo 10, imagem 1 %32 HP Stream 11-y010nr Screen Replacement: passo 10, imagem 2 %32
    • Disconnect the screen from the motherboard by pulling the display cable from its connector.
  11. HP Stream 11-y010nr Screen Replacement: passo 11, imagem 1 %32
    • Unscrew the four 0.4mm screws surrounding the display using a Phillips #00 screwdriver.
  12. HP Stream 11-y010nr Screen Replacement: passo 12, imagem 1 %32 HP Stream 11-y010nr Screen Replacement: passo 12, imagem 2 %32 HP Stream 11-y010nr Screen Replacement: passo 12, imagem 3 %32
    • Gently remove the screen from its holding and lay the screen down on the keyboard. It is still attached to the computer.
  13. HP Stream 11-y010nr Screen Replacement: passo 13, imagem 1 %32 HP Stream 11-y010nr Screen Replacement: passo 13, imagem 2 %32 HP Stream 11-y010nr Screen Replacement: passo 13, imagem 3 %32
    Comprar
    • Take the tweezers and push up on the small connector to the left of the webcam.
  14. HP Stream 11-y010nr Screen Replacement: passo 14, imagem 1 %32 HP Stream 11-y010nr Screen Replacement: passo 14, imagem 2 %32
    • Gently pull the cord out from around the screen area.
  15. HP Stream 11-y010nr Screen Replacement: passo 15, imagem 1 %32 HP Stream 11-y010nr Screen Replacement: passo 15, imagem 2 %32
    • Remove the screen with the display cable attached.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 494
