Introdução
This guide will show the step by step process of disassembling the HP stream in order to remove and replace the battery.
O que você precisa
Turn off your HP Stream 11-r020nr by holding the power button down for 10 seconds.
Turn the device top down so the rubber feet are facing up.
Use a metal spudger to remove all the rubber feet off of the bottom of the device, including the small ones. This will uncover 6 screws for a total of 11 screws.
Uma outra pessoa concluiu este guia.
