Introdução
This guide will walk you through the process of removing the lid from an HP Stream 11 laptop. This should take you about 10-15 minutes. This is a fairly simple device. Make sure to use caution when you remove the wires so you don't damage them or the components they are attached to.
O que você precisa
Pry off the two elliptical rubber inserts (one in each corner).
Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
Tilt the top of the keyboard plate up until you separate it from the base.
Tilt the keyboard toward you slowly but do not remove it, it is still connected with ribbon cables.
Lift the black flap on the display cable ZIF connector.
After lifting the flap, gently pull the display cable from its socket.
Disconnect the wireless antenna from the wireless card.
Remove the four 2.2 mm Phillips #00 screws on the left and right sides of the laptop.
Uma outra pessoa concluiu este guia.
