Ir para o conteúdo principal
HP Stream 11-d008TU Keyboard Assembly Replacement
O que você precisa
  1. HP Stream 11-d008TU Keyboard Assembly Replacement, Rubber Feet Removal: passo 1, imagem 1 %32 HP Stream 11-d008TU Keyboard Assembly Replacement, Rubber Feet Removal: passo 1, imagem 2 %32 HP Stream 11-d008TU Keyboard Assembly Replacement, Rubber Feet Removal: passo 1, imagem 3 %32
    • Use a prying tool to pry the 2 rubber feet off closest to the hinge of the device
    • Repeat this process for the other side of the device
    • The bottom rubber feet do not have hidden screws underneath them, and as such, they are unnecessary to remove
  2. HP Stream 11-d008TU Keyboard Assembly Replacement, Screw removal: passo 2, imagem 1 %32 HP Stream 11-d008TU Keyboard Assembly Replacement, Screw removal: passo 2, imagem 2 %32
    • Remove the 11x 5mm Phillips PH-0 screws (circled)
  3. HP Stream 11-d008TU Keyboard Assembly Replacement, Keyboard Unclipping: passo 3, imagem 1 %32 HP Stream 11-d008TU Keyboard Assembly Replacement, Keyboard Unclipping: passo 3, imagem 2 %32 HP Stream 11-d008TU Keyboard Assembly Replacement, Keyboard Unclipping: passo 3, imagem 3 %32
    • Use your finger to pry the outer blue shell over the keyboard
    • Continue this process around the edges of the device
    • You may have to use a prying tool to pry the harder edges such as around the I/O ports
    • Do not lift the keyboard once all the clips are undone, as there are still various cables connected
  4. HP Stream 11-d008TU Keyboard Assembly Replacement, Keyboard removal: passo 4, imagem 1 %32 HP Stream 11-d008TU Keyboard Assembly Replacement, Keyboard removal: passo 4, imagem 2 %32 HP Stream 11-d008TU Keyboard Assembly Replacement, Keyboard removal: passo 4, imagem 3 %32
    • Disconnect the power button connector by peeling back the protective tape, using your fingernail to flip the white retaining clip back, and pulling the ribbon cable out
    • Disconnect the touchpad connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Disconnect the keyboard connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Your keyboard assembly is now safe to remove
Conclusão
Uma outra pessoa concluiu este guia.
CONVERSION
Membro desde: 03/07/20
1.252 Reputação
Autoria de 8 guias
Equipe
Australia Membro de Australia
Community
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 85
