Introdução
This guide will showcase the steps necessary to remove the HP Sprocket 2-in-1 camera assembly in case of a fault. Be careful when doing so in a dusty environment as dust can impact image quality after the reinstalling a new lens. Furthermore, be sure to complete this guide in a well-lit environment to avoid potential issues that can arise when handling very small screws.
O que você precisa
Use the Japanese Industrial Standard J00 screwdriver to remove five 2.5mm screws.
Remove the metal plate from the casing.
