Ir para o conteúdo principal
HP Sprocket 2-in-1 Camera Lens Assembly Replacement
O que você precisa
  1. HP Sprocket 2-in-1 Camera Lens Assembly Replacement, Outer Casing: passo 1, imagem 1 %32 HP Sprocket 2-in-1 Camera Lens Assembly Replacement, Outer Casing: passo 1, imagem 2 %32
    • Remove the back cover and any printer paper inside the device.
  2. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: passo 2, imagem 1 %32 HP Sprocket 2-in-1 Camera Lens Assembly Replacement: passo 2, imagem 2 %32
    • Using the Jimmy, slowly pry open the outer edge of the remaining white plastic on the back.
    • Remove the plastic from the device once it lifts out freely.
  3. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: passo 3, imagem 1 %32 HP Sprocket 2-in-1 Camera Lens Assembly Replacement: passo 3, imagem 2 %32 HP Sprocket 2-in-1 Camera Lens Assembly Replacement: passo 3, imagem 3 %32
    • Remove two 2.5mm JIS #00 located on the small circuit board in view.
    • Use the Jimmy to remove the board after the screws have been removed.
    • Be careful not to crease or damage the ribbon cable.
  4. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: passo 4, imagem 1 %32 HP Sprocket 2-in-1 Camera Lens Assembly Replacement: passo 4, imagem 2 %32 HP Sprocket 2-in-1 Camera Lens Assembly Replacement: passo 4, imagem 3 %32
    • Remove two 2.5mm JIS #00 screws from the translucent plastic bracket.
    • One will be located beneath the ribbon cable.
    • Remove the translucent plastic bracket by hand.
  5. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: passo 5, imagem 1 %32 HP Sprocket 2-in-1 Camera Lens Assembly Replacement: passo 5, imagem 2 %32
    • Remove four 2.5mm JIS #00 screws from the beige casing.
  6. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: passo 6, imagem 1 %32 HP Sprocket 2-in-1 Camera Lens Assembly Replacement: passo 6, imagem 2 %32 HP Sprocket 2-in-1 Camera Lens Assembly Replacement: passo 6, imagem 3 %32
    • Use the iFixit opening tool to slowly work between the white and beige casing around the device.
    • Flip the device over and seperate the white casing from the rest of the device.
    • Be careful not to break the plastic while removing the case.
    • Gently remove the white casing as there is a ribbon cable connecting the two pieces.
  7. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: passo 7, imagem 1 %32
    • Carefully remove the ribbon cable that connects the flash to the outer casing.
  8. HP Sprocket 2-in-1 Camera Lens Assembly Replacement, Camera Lens Assembly: passo 8, imagem 1 %32 HP Sprocket 2-in-1 Camera Lens Assembly Replacement, Camera Lens Assembly: passo 8, imagem 2 %32
    • Use the Japanese Industrial Standard J00 screwdriver to remove five 2.5mm screws.
    • One of the screws is below bronze tape. Move the tape slightly to get to the screw.
    • Remove the metal plate from the casing.
  9. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: passo 9, imagem 1 %32
    • Use an iFixit opening tool to pry the camera free from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 264
