Ir para o conteúdo principal
HP Split x2 Screen Replacement
O que você precisa
  1. HP Split x2 Screen Replacement, Rear Cover: passo 1, imagem 1 %32
    • Opening the device voids the manufacturer warranty.
    • Power down the HP Split x2 before beginning the repair
    • Separate the tablet from the keyboard by pushing the slider to the left and lifting the tablet from the keyboard.
  2. HP Split x2 Screen Replacement: passo 2, imagem 1 %32 HP Split x2 Screen Replacement: passo 2, imagem 2 %32 HP Split x2 Screen Replacement: passo 2, imagem 3 %32
    • Remove the four white caps on the bottom edge of the tablet.
    • Use a tweezer to grasp white caps.
    • The white caps are easily lost. Store them in a secure place.
  3. HP Split x2 Screen Replacement: passo 3, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the four 3mm screws.
  4. HP Split x2 Screen Replacement: passo 4, imagem 1 %32 HP Split x2 Screen Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to pry the tabs on the top, left and right sides of the tablet.
    • Only the top and sides have tabs. Remove all tabs before lifting screen.
  5. HP Split x2 Screen Replacement: passo 5, imagem 1 %32 HP Split x2 Screen Replacement: passo 5, imagem 2 %32
    • Separate the cover and the screen.
    • Gently lift the screen out of the cover.
  6. HP Split x2 Screen Replacement, Screen: passo 6, imagem 1 %32 HP Split x2 Screen Replacement, Screen: passo 6, imagem 2 %32
    • Use a J0 screwdriver to remove the ten 4mm Phillips screws.
  7. HP Split x2 Screen Replacement: passo 7, imagem 1 %32 HP Split x2 Screen Replacement: passo 7, imagem 2 %32
    • Peel back the large black tape.
    • Remove the 4mm Phillips screw.
  8. HP Split x2 Screen Replacement: passo 8, imagem 1 %32 HP Split x2 Screen Replacement: passo 8, imagem 2 %32 HP Split x2 Screen Replacement: passo 8, imagem 3 %32
    • Remove three 2 mm zero insertion force (ZIF) connectors. Lift the black tab in front and then remove the ribbon from the rear.
    • Remove two larger zero insertion force (ZIF) connectors. Lift the black tab in front and then remove the ribbon from the rear.
  9. HP Split x2 Screen Replacement: passo 9, imagem 1 %32 HP Split x2 Screen Replacement: passo 9, imagem 2 %32 HP Split x2 Screen Replacement: passo 9, imagem 3 %32
    Ferramenta utilizada neste passo:
    • The last attachment to the screen is the bronze colored display cable connector.
    • Use a pair of tweezers to lift the metal bar and swing it to the other side on top of the cable.
    • Pull in the direction of the cable to remove the connector.
  10. HP Split x2 Screen Replacement: passo 10, imagem 1 %32
    • Glue is holding the device together along the edges. The glue is can be very strong. A heat gun may be required to loosen the glue for removal of the digitizer to prevent damage to the screen.
    • Apply pressure to to the sides of the tablet.
    • Separate the digitizer from the the body of the tablet.
  11. HP Split x2 Screen Replacement: passo 11, imagem 1 %32 HP Split x2 Screen Replacement: passo 11, imagem 2 %32
    • Glue is holding the screen on at the four corners.
    • Lift the screen up, breaking any adhesion forced by the glue.
    • Replace the old screen with a new one.
Conclusão
11 outras pessoas executaram este guia.
Ricky Huitema
Membro desde: 09/24/15
464 Reputação
Autoria de 2 guias
Equipe
Texas Tech, Team 22-5, Rauch Fall 2015 Membro de Texas Tech, Team 22-5, Rauch Fall 2015
TTU-RAUCH-F15S22G5
Membros da 3
Autoria de 2 guias
5 comentários
This is not helpful because the one I am working on has no screws.
Matt Brown - Responder
I also have a Split x2 with no screws
dbmacaulay -
I want change my screen because My screen is broken but I do not know , where I can buy my screen
Nohora Chitiva - Responder
ebay or amazon
Andrei Isari -
Is HP Touch Screen Digitizer Glass for HP Split X2 The same as the screen being replaced here?? I need to know
Nwatu Chineme Edger - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 22
Duração total: 13,359
