Ir para o conteúdo principal
HP Split x2 Rear Cover Replacement
O que você precisa
  1. HP Split x2 Rear Cover Replacement, Rear Cover: passo 1, imagem 1 %32
    • Opening the device voids the manufacturer warranty.
    • Power down the HP Split x2 before beginning the repair
    • Separate the tablet from the keyboard by pushing the slider to the left and lifting the tablet from the keyboard.
  2. HP Split x2 Rear Cover Replacement: passo 2, imagem 1 %32 HP Split x2 Rear Cover Replacement: passo 2, imagem 2 %32 HP Split x2 Rear Cover Replacement: passo 2, imagem 3 %32
    • Remove the four white caps on the bottom edge of the tablet.
    • Use a tweezer to grasp white caps.
    • The white caps are easily lost. Store them in a secure place.
  3. HP Split x2 Rear Cover Replacement: passo 3, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the four 3mm screws.
  4. HP Split x2 Rear Cover Replacement: passo 4, imagem 1 %32 HP Split x2 Rear Cover Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to pry the tabs on the top, left and right sides of the tablet.
    • Only the top and sides have tabs. Remove all tabs before lifting screen.
  5. HP Split x2 Rear Cover Replacement: passo 5, imagem 1 %32 HP Split x2 Rear Cover Replacement: passo 5, imagem 2 %32
    • Separate the cover and the screen.
    • Gently lift the screen out of the cover.
Conclusão
7 outras pessoas executaram este guia.
Ricky Huitema
Membro desde: 09/24/15
464 Reputação
Autoria de 2 guias
Equipe
Texas Tech, Team 22-5, Rauch Fall 2015 Membro de Texas Tech, Team 22-5, Rauch Fall 2015
TTU-RAUCH-F15S22G5
3 Membros
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 30
Ao todo: 4,206
