Ir para o conteúdo principal
HP Split x2 13-g210dx Back Panel Replacement
O que você precisa
  1. HP Split x2 13-g210dx Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
How do I put the felt cover back on?
Prince Phoenix - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 392
