Ir para o conteúdo principal
HP Split x2 13-g210dx Audio Ports Replacement
O que você precisa
  1. HP Split x2 13-g210dx Audio Ports Replacement, Back Panel: passo 1, imagem 1 %32
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
  2. HP Split x2 13-g210dx Audio Ports Replacement, Battery: passo 2, imagem 1 %32
    • Remove the three 6-mm Phillips #0 screws.
  3. HP Split x2 13-g210dx Audio Ports Replacement: passo 3, imagem 1 %32 HP Split x2 13-g210dx Audio Ports Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the white connector clip from the connector port using a sturdy tweezers.
  4. HP Split x2 13-g210dx Audio Ports Replacement: passo 4, imagem 1 %32 HP Split x2 13-g210dx Audio Ports Replacement: passo 4, imagem 2 %32
    • Lift the battery away from the device.
  5. HP Split x2 13-g210dx Audio Ports Replacement, Audio Port: passo 5, imagem 1 %32
    • Remove the two 4-mm Phillips #0 screws.
  6. HP Split x2 13-g210dx Audio Ports Replacement: passo 6, imagem 1 %32 HP Split x2 13-g210dx Audio Ports Replacement: passo 6, imagem 2 %32 HP Split x2 13-g210dx Audio Ports Replacement: passo 6, imagem 3 %32
    Comprar
    • Remove the two purple ribbons labeled "Audio" at the top of the audio port board using tweezers or a sturdy plastic opening tool.
  7. HP Split x2 13-g210dx Audio Ports Replacement: passo 7, imagem 1 %32 HP Split x2 13-g210dx Audio Ports Replacement: passo 7, imagem 2 %32
    • Remove the white clip at the top right corner of the audio port board using tweezers.
  8. HP Split x2 13-g210dx Audio Ports Replacement: passo 8, imagem 1 %32
    • Lift the Audio port away from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 227
