Introdução
If your battery is no longer performing to its full potential and can no longer hold a charge, use this guide to help you remove and replace the battery. Please note that this guide is specifically for the HP Spectre x360 15-bl012dx.
A battery is a component of the laptop that provides power. Due to overuse and time, laptop batteries will be worn out and rapidly drain after being charged a repeated amount of time. If the battery is worn out and draining rapidly, consider replacing the battery to help the laptop perform to its highest functionality.
Before starting this guide, please be sure to review the troubleshooting page for extra information on battery hazards.
Please make sure the laptop is turned off and disconnected from the charging adapter before you begin the repair.
O que você precisa
Place the computer so that the back panel is facing up. Begin by removing the two visible Torx T5 9 mm screws near the hinges.
Next, remove the four visible Torx T5 3 mm on the sides.
Uma outra pessoa concluiu este guia.
5 comentários
Excellent guidance, many thanks!
Anyone know if this is compatible?
Thanks for the guide! Figured there were screws under the rear feet but this confirmed it and prevented me from doing something silly.
Where are you guys finding replacement batteries from? I don't want to go through the process of buying and returning crappy batteries
