Introdução
This guide will instruct you on how to remove and replace the SD card reader. The SD card reader may need to be replaced if it is not working. First, you will need to remove the backplate and battery by following the respective steps.
O que você precisa
Turn off and unplug the laptop.
Flip over the laptop so that the bottom backplate is exposed.
With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
With the screws removed, disconnect the 3 wires connected to the battery.
Remove the 2 mm long Phillips #000 head screw on the SD Card Reader.
Using a plastic spudger, release the pressure connector marked with the green rectangle by gently prying up from below.
Once the pressure connector is undone, the white ribbon cable connected to the SD Card Reader will pull out with no resistance.
With the ribbon cable disconnected and the screw out, the SD Card Reader will be free to remove and replace.
