Introdução
This guide will instruct you on how to remove and replace the fan. Replacement of the fan may be necessary if the laptop is overheating.
O que você precisa
Turn off and unplug the laptop.
Flip over the laptop so that the bottom backplate is exposed.
Use a Phillips #0 screwdriver to unscrew and remove the two 4 mm screws that secure the fan.
Use the same screwdriver to remove the four 3 mm screws to free the heat sink.
Quase terminado!
Conclusão
