Ir para o conteúdo principal
HP Spectre x360 13t-4000 Bottom Cover Replacement
O que você precisa
  1. HP Spectre x360 13t-4000 Bottom Cover Replacement, Bottom Cover: passo 1, imagem 1 %32 HP Spectre x360 13t-4000 Bottom Cover Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Bottom Cover Replacement: passo 2, imagem 1 %32 HP Spectre x360 13t-4000 Bottom Cover Replacement: passo 2, imagem 2 %32
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Bottom Cover Replacement: passo 3, imagem 1 %32 HP Spectre x360 13t-4000 Bottom Cover Replacement: passo 3, imagem 2 %32 HP Spectre x360 13t-4000 Bottom Cover Replacement: passo 3, imagem 3 %32
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Um comentário
Any idea for previous model like acxxxx? The 5mm screw aren't visible, bit it's like if they are there. The corners won't come out. Is the screws hidden deep under the rubber pad? Removed the rubber, do we need to somehow remove the plastic part on which the rubber pad are glued? If so how? They seems to be glued on
Ben - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 1,115
