Ir para o conteúdo principal
HP Spectre x360 13-aw0xxx Battery Replacement
O que você precisa
  1. HP Spectre x360 13-aw0xxx Battery Replacement, Lower Case: passo 1, imagem 1 %32 HP Spectre x360 13-aw0xxx Battery Replacement, Lower Case: passo 1, imagem 2 %32
    • Remove the following screws securing the lower case:
    • Four Phillips #00 6 mm screws
    • Two T5 Torx 3 mm screws
  2. HP Spectre x360 13-aw0xxx Battery Replacement: passo 2, imagem 1 %32
    • Insert an opening tool in the seam between the lower case and chassis.
    • Pry around the perimeter until the lower case fully releases.
    • Remove the lower case.
  3. HP Spectre x360 13-aw0xxx Battery Replacement, Battery: passo 3, imagem 1 %32 HP Spectre x360 13-aw0xxx Battery Replacement, Battery: passo 3, imagem 2 %32
    • Use two opening tools, one on either side of the battery plug, to slowly pull the plug straight out of its port.
    • Alternatively, use your fingernails.
  4. HP Spectre x360 13-aw0xxx Battery Replacement: passo 4, imagem 1 %32 HP Spectre x360 13-aw0xxx Battery Replacement: passo 4, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws securing the battery.
  5. HP Spectre x360 13-aw0xxx Battery Replacement: passo 5, imagem 1 %32 HP Spectre x360 13-aw0xxx Battery Replacement: passo 5, imagem 2 %32
    • Carefully lift the edge of the battery with an opening tool.
    • Lift the battery up and out.
Conclusão
Thomas Hayslett
Membro desde: 02/14/23
97 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 24
Últimos 30 dias: 169
Duração total: 1,557
