Ir para o conteúdo principal
HP Spectre x360 13-ac023dx WiFi Card Replacement
O que você precisa
  1. HP Spectre x360 13-ac023dx WiFi Card Replacement, Battery: passo 1, imagem 1 %32 HP Spectre x360 13-ac023dx WiFi Card Replacement, Battery: passo 1, imagem 2 %32
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre x360 13-ac023dx WiFi Card Replacement: passo 2, imagem 1 %32 HP Spectre x360 13-ac023dx WiFi Card Replacement: passo 2, imagem 2 %32 HP Spectre x360 13-ac023dx WiFi Card Replacement: passo 2, imagem 3 %32
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre x360 13-ac023dx WiFi Card Replacement: passo 3, imagem 1 %32 HP Spectre x360 13-ac023dx WiFi Card Replacement: passo 3, imagem 2 %32
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectre x360 13-ac023dx WiFi Card Replacement, WiFi Card: passo 4, imagem 1 %32
    • Locate the WiFi card.
  5. HP Spectre x360 13-ac023dx WiFi Card Replacement: passo 5, imagem 1 %32
    • Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
  6. HP Spectre x360 13-ac023dx WiFi Card Replacement: passo 6, imagem 1 %32 HP Spectre x360 13-ac023dx WiFi Card Replacement: passo 6, imagem 2 %32
    • Once the screw is removed, raise the WiFi card and slide it out from the motherboard.
Conclusão
Jonathan
Membro desde: 10/21/19
486 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S1-G6, Botvin Fall 2019 Membro de UMass Dartmouth, Team S1-G6, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G6
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 17
Duração total: 1,837
