Ir para o conteúdo principal
HP Spectre x360 13-ac023dx Motherboard Replacement
O que você precisa
  1. HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: passo 1, imagem 1 %32 HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre x360 13-ac023dx Motherboard Replacement: passo 2, imagem 1 %32 HP Spectre x360 13-ac023dx Motherboard Replacement: passo 2, imagem 2 %32 HP Spectre x360 13-ac023dx Motherboard Replacement: passo 2, imagem 3 %32
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre x360 13-ac023dx Motherboard Replacement: passo 3, imagem 1 %32 HP Spectre x360 13-ac023dx Motherboard Replacement: passo 3, imagem 2 %32
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectre x360 13-ac023dx Motherboard Replacement, Fan: passo 4, imagem 1 %32
    • Locate the Cooling Fan in the device.
  5. HP Spectre x360 13-ac023dx Motherboard Replacement: passo 5, imagem 1 %32 HP Spectre x360 13-ac023dx Motherboard Replacement: passo 5, imagem 2 %32
    • Use the Phillips #000 screwdriver to remove the 3mm screws holding the fan in place.
    • Remove the wires connecting to the motherboard, using the iFixit opening tool.
    • The iFixit Opening Tool is not required, but recommended
  6. HP Spectre x360 13-ac023dx Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the Cooling Fan.
  7. HP Spectre x360 13-ac023dx Motherboard Replacement, WiFi Card: passo 7, imagem 1 %32
    • Locate the WiFi card.
  8. HP Spectre x360 13-ac023dx Motherboard Replacement: passo 8, imagem 1 %32
    • Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
  9. HP Spectre x360 13-ac023dx Motherboard Replacement: passo 9, imagem 1 %32 HP Spectre x360 13-ac023dx Motherboard Replacement: passo 9, imagem 2 %32
    • Once the screw is removed, raise the WiFi card and slide it out from the motherboard.
  10. HP Spectre x360 13-ac023dx Motherboard Replacement, Motherboard: passo 10, imagem 1 %32
    • Ensure that all other components which were previously removed are not longer attached.
  11. HP Spectre x360 13-ac023dx Motherboard Replacement: passo 11, imagem 1 %32 HP Spectre x360 13-ac023dx Motherboard Replacement: passo 11, imagem 2 %32 HP Spectre x360 13-ac023dx Motherboard Replacement: passo 11, imagem 3 %32
    • Disconnect the wires which connect the motherboard to the rest of the components.
    • The black and red wire can be removed by pulling the wire upwards.
  12. HP Spectre x360 13-ac023dx Motherboard Replacement: passo 12, imagem 1 %32 HP Spectre x360 13-ac023dx Motherboard Replacement: passo 12, imagem 2 %32 HP Spectre x360 13-ac023dx Motherboard Replacement: passo 12, imagem 3 %32
    • Use the Phillips #000 screwdriver to remove the three 3.5 mm screws which keep the motherboard in place.
  13. HP Spectre x360 13-ac023dx Motherboard Replacement: passo 13, imagem 1 %32 HP Spectre x360 13-ac023dx Motherboard Replacement: passo 13, imagem 2 %32
    • Carefully lift and remove the motherboard.
Conclusão
Jonathan
Membro desde: 10/21/19
486 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S1-G6, Botvin Fall 2019 Membro de UMass Dartmouth, Team S1-G6, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G6
Membros da 3
Autoria de 6 guias
Um comentário
Can I get ho spectre x360 motherboard to buy from your end?
Immanuel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 51
Duração total: 3,469
