Introdução
Many times the speaker(s) on your device can stop functioning properly due to several reasons. This guide shows how to replace the speaker(s) on this device.
O que você precisa
Make sure the device is powered off and the kick stand is retracted.
The HP Spectre should be placed on a flat surface with the keyboard detached.
Ferramenta utilizada nesse passo:Tweezers$4.99
To remove the screen, there is an entire system of clips which need to be undone as well as 4 Phillips M1.5x2.7 screws.
The screws should be removed using a Phillips #000 screwdriver. There is a sticker where the laptop attaches to the keyboard.
Heat the sticker (if needed) and use fine point tweezers to grip the sticker and remove it.
