Ir para o conteúdo principal
HP Spectre x2 12-a002dx Screen Replacement
O que você precisa
  1. HP Spectre x2 12-a002dx Screen Replacement, Screen: passo 1, imagem 1 %32
    • Make sure the device is powered off and the kick stand is retracted.
    • The HP Spectre should be placed on a flat surface with the keyboard detached.
  2. HP Spectre x2 12-a002dx Screen Replacement: passo 2, imagem 1 %32 HP Spectre x2 12-a002dx Screen Replacement: passo 2, imagem 2 %32 HP Spectre x2 12-a002dx Screen Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • To remove the screen, there is an entire system of clips which need to be undone as well as 4 Phillips M1.5x2.7 screws.
    • The screws should be removed using a Phillips #000 screwdriver. There is a sticker where the laptop attaches to the keyboard.
    • Heat the sticker (if needed) and use fine point tweezers to grip the sticker and remove it.
  3. HP Spectre x2 12-a002dx Screen Replacement: passo 3, imagem 1 %32 HP Spectre x2 12-a002dx Screen Replacement: passo 3, imagem 2 %32 HP Spectre x2 12-a002dx Screen Replacement: passo 3, imagem 3 %32
    • Use the plastic opening tools or insert a spudger to begin unclipping the system.
    • Pry the screen off once all the clips have been unclipped.
    • The screen may shatter if not already shattered (beware of flying glass).
    • This screen will break. There is double tape underneath the frame, which is not listed in here.
  4. HP Spectre x2 12-a002dx Screen Replacement: passo 5, imagem 1 %32 HP Spectre x2 12-a002dx Screen Replacement: passo 5, imagem 2 %32 HP Spectre x2 12-a002dx Screen Replacement: passo 5, imagem 3 %32
    • Remove the connecting cable of the screen and battery. Use a spudger to reveal the adhesive strip and carefully peel it off.
    • Insert a spudger to the other end and release the ZIF connectors. Detach the cable.
    • While a metal spudger is pictured, use a black nylon spudger instead because it is ESD safe.
Conclusão
5 outras pessoas executaram este guia.
Talha Bin Amir
Membro desde: 10/23/17
683 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S10-G6, Thompson Fall 2017 Membro de USF Tampa, Team S10-G6, Thompson Fall 2017
USFT-THOMPSON-F17S10G6
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 15
Últimos 30 dias: 46
Duração total: 4,447
