Ir para o conteúdo principal
HP Spectre 13-4002dx Motherboard Replacement
O que você precisa
  1. HP Spectre 13-4002dx Motherboard Replacement, Bottom Case: passo 1, imagem 1 %32 HP Spectre 13-4002dx Motherboard Replacement, Bottom Case: passo 1, imagem 2 %32
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Motherboard Replacement: passo 2, imagem 1 %32 HP Spectre 13-4002dx Motherboard Replacement: passo 2, imagem 2 %32
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Motherboard Replacement, Battery: passo 3, imagem 1 %32 HP Spectre 13-4002dx Motherboard Replacement, Battery: passo 3, imagem 2 %32 HP Spectre 13-4002dx Motherboard Replacement, Battery: passo 3, imagem 3 %32
    • Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
    • Remove the six 4 mm screws using a Phillips #000 screwdriver.
  4. HP Spectre 13-4002dx Motherboard Replacement: passo 4, imagem 1 %32 HP Spectre 13-4002dx Motherboard Replacement: passo 4, imagem 2 %32 HP Spectre 13-4002dx Motherboard Replacement: passo 4, imagem 3 %32
    • Do not disconnect the cable connector shown in the red box.
    • The speaker cable may be attached to the battery with black electrical tape. If so, remove the tape.
    • Move the cable clear of the battery.
  5. HP Spectre 13-4002dx Motherboard Replacement: passo 5, imagem 1 %32 HP Spectre 13-4002dx Motherboard Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Do not disconnect the cable connector located in the red box.
    • Use tweezers to remove the speaker cable from the groove attached to the battery.
    • Push the cable to the side so it does not get in the way of the battery removal.
  6. HP Spectre 13-4002dx Motherboard Replacement: passo 6, imagem 1 %32 HP Spectre 13-4002dx Motherboard Replacement: passo 6, imagem 2 %32 HP Spectre 13-4002dx Motherboard Replacement: passo 6, imagem 3 %32
    • Disconnect the battery cable connector by sliding it out of the socket.
    • Move the battery out of the way if you need more room to disconnect the power cable.
  7. HP Spectre 13-4002dx Motherboard Replacement: passo 7, imagem 1 %32
    • Carefully remove the battery.
  8. HP Spectre 13-4002dx Motherboard Replacement, Motherboard: passo 8, imagem 1 %32 HP Spectre 13-4002dx Motherboard Replacement, Motherboard: passo 8, imagem 2 %32 HP Spectre 13-4002dx Motherboard Replacement, Motherboard: passo 8, imagem 3 %32
    • Remove the black tape from the motherboard.
    • Remove five screws using the Phillips #00 screwdriver that holds the motherboard in place.
    • Disconnect five ribbon cables, three power cables, and two wifi antennas from the motherboard.
    • Gently lift the motherboard out of the computer. Be careful to not to disturb the CPU fan.
    • Do not bend the motherboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 470
