Ir para o conteúdo principal
HP Spectre 13-4002dx Display Replacement
O que você precisa
  1. HP Spectre 13-4002dx Display Replacement, Motherboard: passo 1, imagem 1 %32 HP Spectre 13-4002dx Display Replacement, Motherboard: passo 1, imagem 2 %32 HP Spectre 13-4002dx Display Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the black tape from the motherboard.
    • Remove five screws using the Phillips #00 screwdriver that holds the motherboard in place.
    • Disconnect five ribbon cables, three power cables, and two wifi antennas from the motherboard.
    • Gently lift the motherboard out of the computer. Be careful to not to disturb the CPU fan.
    • Do not bend the motherboard.
  2. HP Spectre 13-4002dx Display Replacement, Display: passo 2, imagem 1 %32
    • Remove four screws connecting the screen to the laptop case with the Phillips #00 screwdriver.
  3. HP Spectre 13-4002dx Display Replacement: passo 3, imagem 1 %32 HP Spectre 13-4002dx Display Replacement: passo 3, imagem 2 %32
    • Bring the laptop screen to a 270 degree angle from the base.
    • Pull the display towards you for the display to pop out of the base.
    • Gently remove the display to ensure that the cables do not get caught on the case.
  4. HP Spectre 13-4002dx Display Replacement: passo 4, imagem 1 %32 HP Spectre 13-4002dx Display Replacement: passo 4, imagem 2 %32
    • Remove the rubber seal around display with the opening tool.
    • Pry the display off.
    • Be careful while removing the display as it could snap and cause damage and/or injury. Be careful to not cut any wiring between the screen and its casing.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 435
