Introdução
This guide will give you step-by-step instructions on how to remove your touchpad. Make sure you have a clean, dry, uncluttered, and roomy work space that has good lighting before you start. Also, make sure that your touchpad actually needs to be replaced by consulting our troubleshooting guide.
O que você precisa
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95
Turn the computer upside down.
Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
Using a plastic opening tool, lift the locking bar on the trackpad ZIF connector.
Gently pull the cable out.
