Introdução
This guide will give you step-by-step instructions on how to remove your touchpad. Make sure you have a clean, dry, uncluttered, and roomy work space that has good lighting before you start. Also, make sure that your touchpad actually needs to be replaced by consulting our troubleshooting guide.
Ferramentas
Peças
Não são necessárias peças.
Turn the computer upside down.
Use the T4 Torx Screwdriver to remove the eight 3.3 mm screws.
Using a plastic opening tool, lift the locking bar on the trackpad ZIF connector.
Gently pull the cable out.
