Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95-
Turn the computer upside down.
Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
Use an opening tool to pry up and loosen the back case from the laptop.
Remove the back case.
Remove the four 2mm Phillips #00 screws securing the battery.
Peel off the adhesive on the left side of the battery holding the speaker wire down.
Move the battery slightly to gain access to the battery plug, located on the left edge of the battery.
Carefully unplug the battery by pulling the connector towards the battery.
Remove the battery.
Remove the two 2mm Phillips #00 screws from the fan.
Disconnect the fan from the motherboard.
Using minimal force, disconnect both WiFi antennae cables.
Remove the single Phillips #00 screw that secures the WiFi card.
Slide the WiFi card up until it is completely removed.
Remove the four hinge screw with a Phillips #00 screwdriver.
Separate the display assembly from the body of the computer.
7 outras pessoas executaram este guia.
2 comentários
You forgot to mention that some people may have to remove the heatsink like I did before the screen will come off.
Anyone have any tips on reconnecting the WIFI antennas? I finally gave up and just decided to get a USB dongle… worked out well otherwise. I did also have to remove the heatsink like Wargaming Super Noob mentioned.
