Introdução
This guide will give you step-by-step instructions on how to replace your display assembly. Make sure you have a clean, dry, uncluttered, and roomy work space that has good lighting before you start. Also, make sure that your display assembly actually needs to be replaced by consulting our troubleshooting guide.
O que você precisa
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95
Turn the computer upside down.
Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
Remove the two 2mm Phillips #00 screws from the fan.
Disconnect the fan from the motherboard.
7 outras pessoas executaram este guia.
2 comentários
You forgot to mention that some people may have to remove the heatsink like I did before the screen will come off.
Anyone have any tips on reconnecting the WIFI antennas? I finally gave up and just decided to get a USB dongle… worked out well otherwise. I did also have to remove the heatsink like Wargaming Super Noob mentioned.
