Ir para o conteúdo principal
HP Spectre x360 13-ac023dx Battery Replacement
O que você precisa
  1. HP Spectre  x360 13-ac023dx Battery Replacement, Battery: passo 1, imagem 1 %32 HP Spectre  x360 13-ac023dx Battery Replacement, Battery: passo 1, imagem 2 %32
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre  x360 13-ac023dx Battery Replacement: passo 2, imagem 1 %32 HP Spectre  x360 13-ac023dx Battery Replacement: passo 2, imagem 2 %32 HP Spectre  x360 13-ac023dx Battery Replacement: passo 2, imagem 3 %32
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre  x360 13-ac023dx Battery Replacement: passo 3, imagem 1 %32 HP Spectre  x360 13-ac023dx Battery Replacement: passo 3, imagem 2 %32
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
Conclusão
5 outras pessoas executaram este guia.
Dylan Beery
Membro desde: 10/21/19
290 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S1-G6, Botvin Fall 2019 Membro de UMass Dartmouth, Team S1-G6, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G6
Membros da 3
Autoria de 6 guias
4 comentários
The overall procedure is ok, however as others commented instructions on how to remove the feet would be helpful. I tried a heat gun to help loosen the glue, however that just melted the feat. Overall go the job done, but 2 out of the 4 feet were destroyed in the process.
Also in my case there were no screws under the top or bottom feet, so I could have probably removed the cover without removing the feet.
Joseph Ficara - Responder
I think HP quietly refreshed the internals of this laptop or something, because despite appearing externally identical to the laptop shown in the pictures, mine has a smaller main board and differently sized battery. so you should open yours up and check before ordering the battery. mine has the PK03XL. this is double annoying because I was repairing this one for a friend, and she's the one who ordered the battery.
csd - Responder
just finished my repair of my w-013 version. good to know that the top two feet have screws underneath them - small risk of denting the bottom cover if you're not gentle. also, the cable is slightly too long to fit neatly in the battery receptacle - it required some jamming that i'll probably be concerned about for a while.
pkim - Responder
This guide was helpful but my bottom two feet didn't have screws. I used a T4 instead of T5 and for the Phillips a T0 and a T1.
The battery had two metal stickers on it under the bottom feet so I put them on the replacement battery in the same place.
My model is 13-ac033dx
Oliver Hansen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 38
Últimos 30 dias: 142
Duração total: 9,079
