Ir para o conteúdo principal
HP Slate 8 Pro Speakers Replacement
O que você precisa
  1. HP Slate 8 Pro Speakers Replacement, Remove back cover: passo 1, imagem 1 %32
    • Use plastic opening tool to pry back panel off.
  2. HP Slate 8 Pro Speakers Replacement, Detach IO Board from system: passo 2, imagem 1 %32 HP Slate 8 Pro Speakers Replacement, Detach IO Board from system: passo 2, imagem 2 %32
    • Remove the orange and yellow ribbon cables.
    • detach the screws along the IO board
  3. HP Slate 8 Pro Speakers Replacement, Remove the IO board and the speakers: passo 3, imagem 1 %32
    • Remove the IO board and the speakers circuit. Note that they are held together.
  4. HP Slate 8 Pro Speakers Replacement, Detach the speakers from the IO board.: passo 4, imagem 1 %32
    • The tablet has two speakers. Each speaker is located to both sides of the IO board.
    • Detach the speakers from the cables that connect the speakers and the IO board. You will find more details in step 5 and 6.
  5. HP Slate 8 Pro Speakers Replacement, Remove the wires of the speakers from the IO board.: passo 5, imagem 1 %32
    • To remove the cables that connect the speakers and the IO board, apply a subtle pressure to pull the cable out.
  6. HP Slate 8 Pro Speakers Replacement, Replace your speakers with the new parts: passo 6, imagem 1 %32 HP Slate 8 Pro Speakers Replacement, Replace your speakers with the new parts: passo 6, imagem 2 %32
    • Once you detach the speakers from the IO board, you should have three pieces as shown.
    • You are ready to replace the speakers.
Conclusão
Uma outra pessoa concluiu este guia.
Jose Revelo
Membro desde: 09/23/14
305 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 9-4, Blackwell Fall 2014 Membro de USF Tampa, Team 9-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 431
