Ir para o conteúdo principal
HP Slate 8 Pro Microphone Replacement
O que você precisa
  1. HP Slate 8 Pro Microphone Replacement, Remove the back cover: passo 1, imagem 1 %32
    • Before opening your device, turn off the tablet. If you are unsure whether the tablet is off or in Hibernation, turn the tablet on, and then shut it down through the operating system.
    • Unplug your tablet from any power supply
    • Remove all external devices.
    • Remove back cover with plastic tools to avoid scratching the screen.
  2. HP Slate 8 Pro Microphone Replacement, Remove screws: passo 2, imagem 1 %32
    • Remove all screws from the sides of the battery
  3. HP Slate 8 Pro Microphone Replacement, Disconnect the battery cable: passo 3, imagem 1 %32
    • Disconnect the battery cable from the system board.
    • Use a little bit of pressure to remove the cable.
  4. HP Slate 8 Pro Microphone Replacement, Remove ZIF connector: passo 4, imagem 1 %32
    • Release the ZIF connector to which the microphone cable is attached
  5. HP Slate 8 Pro Microphone Replacement, Remove the  microphone: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove microphone from panel using tweezers
    • Add your new microphone
Conclusão
Claudia
Membro desde: 08/31/14
246 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 9-4, Blackwell Fall 2014 Membro de USF Tampa, Team 9-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 22
Duração total: 438
