Ir para o conteúdo principal
HP Slate 8 Pro Battery Replacement
O que você precisa
  1. HP Slate 8 Pro Battery Replacement, Remove Back Panel: passo 1, imagem 1 %32 HP Slate 8 Pro Battery Replacement, Remove Back Panel: passo 1, imagem 2 %32
    • Secure the suction cup to the center of the device’s screen.
    • Begin to pull upwards with the suction cup. While pulling, start easing the plastic opening tool into the space between the screen and the device. This will gradually separate the screen from the plastic back panel.
  2. HP Slate 8 Pro Battery Replacement, Remove yellow cables: passo 2, imagem 1 %32 HP Slate 8 Pro Battery Replacement, Remove yellow cables: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a spudger tool to release the black clips on the two connectors holding the flat, yellow cable in place.
    • Use the tweezers to pull the flat, yellow cable out of its connectors.
    • Use the tweezers to disconnect the battery connector from the circuit board.
    • Using the spudger tool again, pry up and release the connectors at the ends of the flat, orange cable.
    • Remove the flat, orange cable.
  3. HP Slate 8 Pro Battery Replacement, Remove Screws Around Battery: passo 3, imagem 1 %32
    • As shown, the battery is held in place by a total of 8 screws. Use the #00 Phillips screwdriver to remove all 8.
  4. HP Slate 8 Pro Battery Replacement, Lift Battery out of Device: passo 4, imagem 1 %32
    • Grasp the battery and remove it from the device.
    • Do not attempt to open or tamper with the battery. This could result in injury.
Conclusão
Uma outra pessoa concluiu este guia.
Jose Revelo
Membro desde: 09/23/14
305 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 9-4, Blackwell Fall 2014 Membro de USF Tampa, Team 9-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 31
Duração total: 3,290
