Ir para o conteúdo principal
HP Slate 7 Plus 4200US Tablet Cover Replacement
O que você precisa
  1. HP Slate 7 Plus 4200US Tablet Cover Replacement, Tablet Cover: passo 1, imagem 1 %32
    • Turn off the tablet and disconnect the power and all external devices from the tablet.
    • Position the tablet with the display panel down and the right side toward you.
    • Carefully insert a plastic opening tool between the tablet cover and display panel assembly, separating the two components. The first insertion point should be between the power button and the volume buttons.
  2. HP Slate 7 Plus 4200US Tablet Cover Replacement: passo 2, imagem 1 %32 HP Slate 7 Plus 4200US Tablet Cover Replacement: passo 2, imagem 2 %32
    • Slide the tool around the perimeter of the tablet until the edge of the cover is completely separated from the display panel assembly.
  3. HP Slate 7 Plus 4200US Tablet Cover Replacement: passo 3, imagem 1 %32 HP Slate 7 Plus 4200US Tablet Cover Replacement: passo 3, imagem 2 %32 HP Slate 7 Plus 4200US Tablet Cover Replacement: passo 3, imagem 3 %32
    • Pry open the back cover to take it off.
Conclusão
Uma outra pessoa concluiu este guia.
Jessica Andrade
Membro desde: 10/04/16
860 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 3-1, Sullivan Fall 2016 Membro de USF Tampa, Team 3-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G1
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 296
