Ir para o conteúdo principal
HP Probook 4425s Keyboard Replacement
O que você precisa
  1. HP Probook 4425s Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 HP Probook 4425s Keyboard Replacement, Keyboard: passo 1, imagem 2 %32
    • Turn off the laptop.
    • Flip over the laptop.
  2. HP Probook 4425s Keyboard Replacement: passo 2, imagem 1 %32
    • Take out the battery.
  3. HP Probook 4425s Keyboard Replacement: passo 3, imagem 1 %32 HP Probook 4425s Keyboard Replacement: passo 3, imagem 2 %32
    • Remove the four 3 mm Phillips head screws that secure the keyboard in place.
  4. HP Probook 4425s Keyboard Replacement: passo 4, imagem 1 %32 HP Probook 4425s Keyboard Replacement: passo 4, imagem 2 %32 HP Probook 4425s Keyboard Replacement: passo 4, imagem 3 %32
    • Flip over and open the laptop.
    • Remove the now loosened cover by grabbing both sides and sliding up.
    • Remove the four 3mm Phillips head black screws directly above the keyboard.
  5. HP Probook 4425s Keyboard Replacement: passo 5, imagem 1 %32 HP Probook 4425s Keyboard Replacement: passo 5, imagem 2 %32 HP Probook 4425s Keyboard Replacement: passo 5, imagem 3 %32
    • Carefully remove the keyboard by sliding it up towards the screen of the computer in order to release the keyboard ribbon cable.
Conclusão
Madyson James
Membro desde: 09/21/18
279 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 254
