Ir para o conteúdo principal
HP ProBook x360 11 G5 EE Display Panel Replacement
O que você precisa
  1. HP ProBook x360 11 G5 EE Display Panel Replacement, Keyboard Assembly: passo 1, imagem 1 %32 HP ProBook x360 11 G5 EE Display Panel Replacement, Keyboard Assembly: passo 1, imagem 2 %32 HP ProBook x360 11 G5 EE Display Panel Replacement, Keyboard Assembly: passo 1, imagem 3 %32
    • Remove the 4.1 mm screws with a T5 Torx screwdriver.
    • Remove the 4.1 mm screws using a JIS #0 screwdriver.
  2. HP ProBook x360 11 G5 EE Display Panel Replacement: passo 2, imagem 1 %32
    • Use an opening pick to pry the corners of the keyboard deck.
  3. HP ProBook x360 11 G5 EE Display Panel Replacement: passo 3, imagem 1 %32 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 3, imagem 2 %32 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 3, imagem 3 %32
    • Use an opening pick or opening tool to pry around the sides of the keyboard assembly.
  4. HP ProBook x360 11 G5 EE Display Panel Replacement: passo 4, imagem 1 %32 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 4, imagem 2 %32 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 4, imagem 3 %32
    • Lift the keyboard assembly to expose two ribbon cables.
    • Lift the two plastic tabs that hold the cables in place on the motherboard
    • Slide the ribbon cables out of each connector.
  5. HP ProBook x360 11 G5 EE Display Panel Replacement: passo 5, imagem 1 %32 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 5, imagem 2 %32
    • Remove the keyboard assembly from the rest of the computer.
  6. HP ProBook x360 11 G5 EE Display Panel Replacement, Battery: passo 6, imagem 1 %32 HP ProBook x360 11 G5 EE Display Panel Replacement, Battery: passo 6, imagem 2 %32
    • Remove the four 3 mm screws from the battery with the JIS #0 screwdriver.
  7. HP ProBook x360 11 G5 EE Display Panel Replacement: passo 7, imagem 1 %32 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 7, imagem 2 %32 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 7, imagem 3 %32
    • Pry the battery up from the laptop using an opening pick.
    • Lift the battery out of its place.
  8. HP ProBook x360 11 G5 EE Display Panel Replacement, Display Panel: passo 8, imagem 1 %32 HP ProBook x360 11 G5 EE Display Panel Replacement, Display Panel: passo 8, imagem 2 %32 HP ProBook x360 11 G5 EE Display Panel Replacement, Display Panel: passo 8, imagem 3 %32
    • Use the opening pick and metal spudger to pry open the display cover.
  9. HP ProBook x360 11 G5 EE Display Panel Replacement: passo 9, imagem 1 %32 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 9, imagem 2 %32
    • Remove the ribbon wire that is attached to the display cover to fully detach it.
  10. HP ProBook x360 11 G5 EE Display Panel Replacement: passo 10, imagem 1 %32 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 10, imagem 2 %32
    • Remove the four 2.3 mm screws holding the screen in place with the JIS #0 screwdriver.
  11. HP ProBook x360 11 G5 EE Display Panel Replacement: passo 11, imagem 1 %32 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 11, imagem 2 %32 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 11, imagem 3 %32
    • Lift the screen to disconnect the wire attaching it to the laptop.
    • Remove the display panel from the rest of the laptop.
Conclusão
Michelle Pina
Membro desde: 10/26/21
506 Reputação
Autoria de 4 guias
Equipe
Gateway, Team 1-4, Pee Fall 2021 Membro de Gateway, Team 1-4, Pee Fall 2021
GCC-PEE-F21S1G4
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 73
Duração total: 2,459
