Ir para o conteúdo principal
HP ProBook x360 11 G5 EE Charging Port Replacement
O que você precisa
  1. HP ProBook x360 11 G5 EE Charging Port Replacement, Keyboard Assembly: passo 1, imagem 1 %32 HP ProBook x360 11 G5 EE Charging Port Replacement, Keyboard Assembly: passo 1, imagem 2 %32 HP ProBook x360 11 G5 EE Charging Port Replacement, Keyboard Assembly: passo 1, imagem 3 %32
    • Remove the 4.1 mm screws with a T5 Torx screwdriver.
    • Remove the 4.1 mm screws using a JIS #0 screwdriver.
  2. HP ProBook x360 11 G5 EE Charging Port Replacement: passo 2, imagem 1 %32
    • Use an opening pick to pry the corners of the keyboard deck.
  3. HP ProBook x360 11 G5 EE Charging Port Replacement: passo 3, imagem 1 %32 HP ProBook x360 11 G5 EE Charging Port Replacement: passo 3, imagem 2 %32 HP ProBook x360 11 G5 EE Charging Port Replacement: passo 3, imagem 3 %32
    • Use an opening pick or opening tool to pry around the sides of the keyboard assembly.
  4. HP ProBook x360 11 G5 EE Charging Port Replacement: passo 4, imagem 1 %32 HP ProBook x360 11 G5 EE Charging Port Replacement: passo 4, imagem 2 %32 HP ProBook x360 11 G5 EE Charging Port Replacement: passo 4, imagem 3 %32
    • Lift the keyboard assembly to expose two ribbon cables.
    • Lift the two plastic tabs that hold the cables in place on the motherboard
    • Slide the ribbon cables out of each connector.
  5. HP ProBook x360 11 G5 EE Charging Port Replacement: passo 5, imagem 1 %32 HP ProBook x360 11 G5 EE Charging Port Replacement: passo 5, imagem 2 %32
    • Remove the keyboard assembly from the rest of the computer.
  6. HP ProBook x360 11 G5 EE Charging Port Replacement, Battery: passo 6, imagem 1 %32 HP ProBook x360 11 G5 EE Charging Port Replacement, Battery: passo 6, imagem 2 %32
    • Remove the four 3 mm screws from the battery with the JIS #0 screwdriver.
  7. HP ProBook x360 11 G5 EE Charging Port Replacement: passo 7, imagem 1 %32 HP ProBook x360 11 G5 EE Charging Port Replacement: passo 7, imagem 2 %32 HP ProBook x360 11 G5 EE Charging Port Replacement: passo 7, imagem 3 %32
    • Pry the battery up from the laptop using an opening pick.
    • Lift the battery out of its place.
  8. HP ProBook x360 11 G5 EE Charging Port Replacement, Charging Port: passo 8, imagem 1 %32 HP ProBook x360 11 G5 EE Charging Port Replacement, Charging Port: passo 8, imagem 2 %32
    • Remove the single 3 mm screw from the charging port using a T5 Torx screwdriver.
  9. HP ProBook x360 11 G5 EE Charging Port Replacement: passo 9, imagem 1 %32 HP ProBook x360 11 G5 EE Charging Port Replacement: passo 9, imagem 2 %32 HP ProBook x360 11 G5 EE Charging Port Replacement: passo 9, imagem 3 %32
    • Disconnect the charging port wire from the motherboard.
    • Remove the charging port from your device.
Conclusão
Uma outra pessoa concluiu este guia.
Michelle Pina
Membro desde: 10/26/21
506 Reputação
Autoria de 4 guias
Equipe
Gateway, Team 1-4, Pee Fall 2021 Membro de Gateway, Team 1-4, Pee Fall 2021
GCC-PEE-F21S1G4
Membros da 5
Autoria de 5 guias
2 comentários
Hi!! I have the same model of notebook with 64 giga emmc. Is it possible installing an ssd or an hdd?
Riccardo Insolera - Responder
I followed each and every step, and realised a little too late that my laptop is a HP ProBook x360 11 G1 -and not a G5. The G1 requires the ability to de-solder the built in charging port.
On step 6, I noticed there were 6 screws holding the battery in, not 4.
Then on step 9, I noticed that the charging port is actually soldered to the motherboard and there is no visible cable attaching it to the board which can be unhooked.
Sam T - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 1,007
