Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
Slide the two battery release latches towards the center of the laptop to release the battery.
Tilt the battery upward.
Remove it from the laptop.
Slide the two release latches that were mentioned in the battery removal process to release the service panel.
Slide the service panel toward you using your thumbs.
Lift it to remove the panel and reveal inner components of the computer.
Using a Phillips #0 Screwdriver, remove the four Phillips 3 mm screws that secure the hard drive into the computer.
Pull the hard drive cover tab to the left in order to disconnect the hard drive from the computer.
Finally, using the same tab, lift the hard drive out of the hard drive port.
7 outras pessoas executaram este guia.
