Ir para o conteúdo principal
HP ProBook 4530s WiFi Card Replacement
O que você precisa
  1. HP ProBook 4530s WiFi Card Replacement, Introduction: passo 1, imagem 1 %32 HP ProBook 4530s WiFi Card Replacement, Introduction: passo 1, imagem 2 %32
    • Start by flipping over the laptop onto its back.
  2. HP ProBook 4530s WiFi Card Replacement, Battery Removal: passo 2, imagem 1 %32
    • Push both switches inward. The battery should pop out a slight amount.
    • Pull out the battery.
  3. HP ProBook 4530s WiFi Card Replacement, Back Panel Removal: passo 3, imagem 1 %32
    • Press on both of the battery switches then push on the back panel forward.
    • It should pop out slightly.
    • Lift and slide the panel off.
  4. HP ProBook 4530s WiFi Card Replacement, Connector Removal: passo 4, imagem 1 %32 HP ProBook 4530s WiFi Card Replacement, Connector Removal: passo 4, imagem 2 %32
    • Locate the WiFi card outlined in red.
    • The golden connectors will need to be popped off. They are marked in blue.
    • Be very careful. If these connectors break, you will have to buy entirely new wires and connectors.
    • Use a nail, a flat-head screwdriver, anything that will be able to pop off the connector gently.
  5. HP ProBook 4530s WiFi Card Replacement, Card Removal: passo 5, imagem 1 %32 HP ProBook 4530s WiFi Card Replacement, Card Removal: passo 5, imagem 2 %32 HP ProBook 4530s WiFi Card Replacement, Card Removal: passo 5, imagem 3 %32
    • Remove the two screws that secure the card down.
    • The card should pop up at a 45 degree angle.
    • Pull the card straight out.
Conclusão
5 outras pessoas executaram este guia.
Drew Canada
Membro desde: 04/03/18
1.370 Reputação
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 40
Duração total: 3,677
