O que você precisa
Press in on both sides, the switches will release the battery.
The battery will pop out slightly, allowing you to pull it out.
Press in on both switches, while pushing onto the plastic panel behind them.
The panel should slide out.
Locate the RAM slightly to the center-left.
Press outward on the metal retention arms for the RAM.
The RAM should pop upward slightly.
6 outras pessoas executaram este guia.
