Ir para o conteúdo principal
HP ProBook 4530s Hard Drive Replacement
O que você precisa
  1. HP ProBook 4530s Hard Drive Replacement, Introduction: passo 1, imagem 1 %32 HP ProBook 4530s Hard Drive Replacement, Introduction: passo 1, imagem 2 %32
    • Start by flipping over the laptop onto its back.
  2. HP ProBook 4530s Hard Drive Replacement, Battery Removal: passo 2, imagem 1 %32 HP ProBook 4530s Hard Drive Replacement, Battery Removal: passo 2, imagem 2 %32
    • Press inward on the two switches.
    • The battery should pop out slightly.
    • Remove the battery.
  3. HP ProBook 4530s Hard Drive Replacement, Back Panel Removal: passo 3, imagem 1 %32 HP ProBook 4530s Hard Drive Replacement, Back Panel Removal: passo 3, imagem 2 %32
    • Press inward on both switches while pushing the center panel away from you. It should slide slightly backwards.
    • Release the switches.
    • Slide the panel the rest of the way out.
  4. HP ProBook 4530s Hard Drive Replacement, Removing HDD: passo 4, imagem 1 %32 HP ProBook 4530s Hard Drive Replacement, Removing HDD: passo 4, imagem 2 %32
    • Unscrew the four screws located on the edges of the base.
    • Lift enough on the right side of the HDD to make it over the plastic paneling.
    • Pull outward.
  5. HP ProBook 4530s Hard Drive Replacement, Removing HDD from Base: passo 5, imagem 1 %32 HP ProBook 4530s Hard Drive Replacement, Removing HDD from Base: passo 5, imagem 2 %32 HP ProBook 4530s Hard Drive Replacement, Removing HDD from Base: passo 5, imagem 3 %32
    • Remove the adhesive from the protective covering over the HDD.
    • Remove the four screws around the edges of the metal base.
    • Pull out the HDD from the base.
  6. HP ProBook 4530s Hard Drive Replacement, Conclusion: passo 6, imagem 1 %32
    • Insert the new HDD or SSD.
Conclusão
8 outras pessoas executaram este guia.
Drew Canada
Membro desde: 04/03/18
1.370 Reputação
Autoria de 4 guias
2 comentários
Clear and easy instructions. It’s nice to encounter a computer with such easy access to the internals.
Lensyl Urbano - Responder
You have saved me time and money from going to my engineer to help me out. Thank you.
Mercy Ayinde - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 20
Últimos 30 dias: 66
Duração total: 12,426
