Introdução
If your laptop screen is cracked or appears dark while the computer is running, replace the screen.
O que você precisa
Flip the 4520s upside-down with the front toward you.
Push the two latches below the battery inwards at the same time.
Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
Use a metal spudger to remove four rubber caps at the bottom of the screen border.
6 outras pessoas executaram este guia.
2 comentários
I need speakers hp probook 4520s i5
