Ir para o conteúdo principal
HP ProBook 450 G8 Thermal Paste Replacement
O que você precisa
  1. HP ProBook 450 G8 Thermal Paste Replacement, Opening the back panel.: passo 1, imagem 1 %32 HP ProBook 450 G8 Thermal Paste Replacement, Opening the back panel.: passo 1, imagem 2 %32 HP ProBook 450 G8 Thermal Paste Replacement, Opening the back panel.: passo 1, imagem 3 %32
    • Remove the 5 screws holding the back panel.
    • Use a prying tool to carefully release all the clips holding the panel in place.
  2. HP ProBook 450 G8 Thermal Paste Replacement, Removing the old thermal paste.: passo 2, imagem 1 %32 HP ProBook 450 G8 Thermal Paste Replacement, Removing the old thermal paste.: passo 2, imagem 2 %32 HP ProBook 450 G8 Thermal Paste Replacement, Removing the old thermal paste.: passo 2, imagem 3 %32
    • Unscrew the 4 screws holding the CPU heatsink and lift it up, gently.
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
  3. HP ProBook 450 G8 Thermal Paste Replacement, Applying new thermal paste.: passo 3, imagem 1 %32
    • Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Last, put the heatsink back carefully and tighten the screws in order 1 -> 4 to ensure even pressure.
  4. HP ProBook 450 G8 Thermal Paste Replacement, Upgrading the RAM and SSD (Optional): passo 4, imagem 1 %32
    • Once you opened the back cover, it is a good idea to upgrade the RAM or the SSD if you want.
    • It is also recommended to use compressed air to remove any dust in the laptop and the fan.
Conclusão
3 outras pessoas executaram este guia.
Simeon Brankov
Membro desde: 11/08/20
7.153 Reputação
Autoria de 54 guias
Um comentário
Super Anleitung, ich brauche allerdings Hilfe und hoffe es kann sich zufällig jemand hier melden.
Auf dem Bild kann man die Steckverbindung sehen die ich versuche zu öffnen.
Ich möchte das Mainboard ausbauen und scheiter an der Steckverbindung (auf dem Bild über dem Akku wo das Hinweis Schild drauf klebt.
"replace with hp parts"
Diese Verbindung schaff ich nicht zu öffnen, wenn jemand helfen kann bitte
Thomas Ragelnau - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 43
Últimos 30 dias: 115
Duração total: 1,837
