Ir para o conteúdo principal
HP ProBook 450 G4 Speaker Replacement
O que você precisa
  1. HP ProBook 450 G4 Speaker Replacement, Hard Drive: passo 1, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement, Hard Drive: passo 1, imagem 2 %32
    • Power your laptop off.
    • Flip the laptop over.
    • Orient the laptop so the two vents on the bottom face upward and are further away from you.
  2. HP ProBook 450 G4 Speaker Replacement: passo 2, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement: passo 2, imagem 2 %32 HP ProBook 450 G4 Speaker Replacement: passo 2, imagem 3 %32
    • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
    • Use the spudger to separate the vent panel from the laptop.
    • Slide the vent panel off the backside of the laptop.
  3. HP ProBook 450 G4 Speaker Replacement: passo 3, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement: passo 3, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the hard drive to the left side of the laptop.
  4. HP ProBook 450 G4 Speaker Replacement: passo 4, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement: passo 4, imagem 2 %32
    • Use the spudger to lift the left side of the hard drive up.
    • Pull the hard drive diagonally to the left to release the hard drive from the laptop.
  5. HP ProBook 450 G4 Speaker Replacement, Keyboard: passo 5, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement, Keyboard: passo 5, imagem 2 %32 HP ProBook 450 G4 Speaker Replacement, Keyboard: passo 5, imagem 3 %32
    • Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
    • Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
  6. HP ProBook 450 G4 Speaker Replacement: passo 6, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement: passo 6, imagem 2 %32 HP ProBook 450 G4 Speaker Replacement: passo 6, imagem 3 %32
    • Use the spudger to press down on the two black tabs that are underneath where the hard drive used to be.
    • Apply pressure to the black tabs until they release and pop out.
  7. HP ProBook 450 G4 Speaker Replacement: passo 7, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement: passo 7, imagem 2 %32 HP ProBook 450 G4 Speaker Replacement: passo 7, imagem 3 %32
    • Orient the laptop so the keyboard is facing upwards and towards you.
    • Insert the spudger in between the edge of the keyboard and the computer frame.
    • Slide the spudger around the edge of the keyboard until the keyboard is loose.
    • Gently pull the keyboard away from the body of the laptop.
    • Do not pull the keyboard all the way off because there is still a connector cable underneath that needs to be disconnected.
  8. HP ProBook 450 G4 Speaker Replacement: passo 8, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement: passo 8, imagem 2 %32
    • Use a spudger to gently lift up the black locking bar on the keyboard connector.
    • Slide the keyboard ribbon out of the connector.
    • Remove the keyboard.
    • To re-attach the keyboard ribbon, slide it into the connector and swing the locking bar down.
  9. HP ProBook 450 G4 Speaker Replacement, Battery: passo 9, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement, Battery: passo 9, imagem 2 %32
    • Flip the laptop back over.
    • Remove the eight 6.8mm T8 Torx screws on the backside of the laptop.
  10. HP ProBook 450 G4 Speaker Replacement: passo 10, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement: passo 10, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the three 6.6mm screws from the upper left corner of the laptop.
  11. HP ProBook 450 G4 Speaker Replacement: passo 11, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement: passo 11, imagem 2 %32
    • Use the spudger to slide the disk drive out of the laptop.
    • Use the Phillips #0 screwdriver to remove the two 3.2mm screws that are underneath where the disk drive previously was.
  12. HP ProBook 450 G4 Speaker Replacement: passo 12, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement: passo 12, imagem 2 %32 HP ProBook 450 G4 Speaker Replacement: passo 12, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the two 6.6mm screws.
  13. HP ProBook 450 G4 Speaker Replacement: passo 13, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement: passo 13, imagem 2 %32
    • Flip the laptop back over so it is facing upwards.
    • Remove the six 6.6mm T8 Torx screws underneath where the keyboard used to be.
  14. HP ProBook 450 G4 Speaker Replacement: passo 14, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement: passo 14, imagem 2 %32 HP ProBook 450 G4 Speaker Replacement: passo 14, imagem 3 %32
    • Use the spudger to disconnect the nine cable connectors that secure the top case of the laptop to the body of the laptop.
    • Be extra careful while disconnecting the cable connectors because they can tear easily.
  15. HP ProBook 450 G4 Speaker Replacement: passo 15, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement: passo 15, imagem 2 %32
    • Insert the spudger in between the top case of the laptop and its outer frame.
    • Slide the spudger around the edge of the laptop until the top case comes off.
    • Remove the top case.
  16. HP ProBook 450 G4 Speaker Replacement: passo 16, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement: passo 16, imagem 2 %32
    • Insert the opening tool underneath the left side of the battery to remove it from the laptop.
  17. HP ProBook 450 G4 Speaker Replacement, Speaker: passo 17, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement, Speaker: passo 17, imagem 2 %32
    • Orient the top case of the laptop so that the internal parts are facing upwards and green rectangular object is closer to you.
    • Identify the two speakers at the top.
  18. HP ProBook 450 G4 Speaker Replacement: passo 18, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement: passo 18, imagem 2 %32 HP ProBook 450 G4 Speaker Replacement: passo 18, imagem 3 %32
    • Use the Phillips #0 Screwdriver to remove the two 3.5mm screws connecting the speakers to the top case of the laptop.
  19. HP ProBook 450 G4 Speaker Replacement: passo 19, imagem 1 %32 HP ProBook 450 G4 Speaker Replacement: passo 19, imagem 2 %32
    • Insert the spudger underneath each speaker to detach them from the top case of the laptop.
Conclusão
3 outras pessoas executaram este guia.
Sebastian Dow
Membro desde: 01/23/20
1.007 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S1-G3, White Winter 2020 Membro de Cal Poly, Team S1-G3, White Winter 2020
CPSU-WHITE-W20S1G3
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 21
Duração total: 728
