Introdução
Your HP ProBook 450 G4 laptop’s hard drive can become ineffective after prolonged use. The best way to fix this problem is to simply replace the hard drive. This guide is designed to help you safely and properly remove your laptop’s hard drive in an easy to follow way. Before beginning, make sure to power off your laptop and disconnect it from all power sources.
O que você precisa
Flip the laptop over.
Orient the laptop so the two vents on the bottom face upward and are further away from you.
Uma outra pessoa concluiu este guia.
