O que você precisa
Flip the G7 ProBook so that the backside faces towards you
Unscrew the 7 screws on the bottom case of the G7 Probook, including the front bottom side
Take your iFixit opening pick (regular guitar picks work as well) and carefully pry open the shell of the back cover.
You can use the iFixit Opening Tool by sticking it in and using the pick to pry out the rest.
Set the back cover aside after prying it open.
TIP: Pry open near the first 3 screws on the top of the back cover and work your way around the back cover.
Unscrew the four screws on the battery
FOR BATTERY REPLACEMENT: Carefully pull off the battery, deposit it away responsibly, and replace it with a new battery.
FOR RESEATING: Remove the battery and go to Step 4
To reassemble your device:
- Click the back cover on the ProBook.
- Screw the cover together
- Plugin the charger and turn on the ProBook and it should be back to normal
2 comentários
HP Assistant has a battery checker and calibration program. You need to plug the ac power to the laptop and charge it to 100% then run the battery checker again to verify. The battery manufacture recommends draining the pattern to 3% then recharge it to extend the life of the battery. Some makers charge to 50% while others are fully charged. It was very easy to replace. Only difficult was prying open the back case. The pick wasn’t working but a thin tiny flat tip did. Just be very care and take your time.
I did the replacement but there is an error. Two of the screw holes are for the chassis cover.
I replace the battery and HP Support Assistant still said it was bad and to replace it.
Turns out the battery system needs a hard reset.
I found the solution. With the laptop off and plugged in, hold the power button until the LED indicator light goes out then release.
The laptop will start charging when Windows loads up. The HP assistant was happy indicating a healthy battery.
