Ir para o conteúdo principal
HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement
O que você precisa
  1. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Battery: passo 1, imagem 1 %32 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Battery: passo 1, imagem 2 %32
    • Make sure the laptop is turned off before you start.
    • Push and hold the release tab on the right and left toward the center.
  2. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: passo 2, imagem 1 %32 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: passo 2, imagem 2 %32
    • Pull the battery out.
  3. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: passo 3, imagem 1 %32 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: passo 3, imagem 2 %32 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: passo 3, imagem 3 %32
    • Push and hold the release tabs on the right and left toward the center again.
  4. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: passo 4, imagem 1 %32
    • Slide the backplate off.
  5. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Hard Disc Drive (HDD): passo 5, imagem 1 %32 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Hard Disc Drive (HDD): passo 5, imagem 2 %32
    • Locate the hard drive, opposite the battery across from the wireless card.
  6. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: passo 6, imagem 1 %32 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: passo 6, imagem 2 %32 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: passo 6, imagem 3 %32
    • Remove all four Phillips #00 screws that hold the hard drive in place.
  7. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: passo 7, imagem 1 %32 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: passo 7, imagem 2 %32 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: passo 7, imagem 3 %32
    • Lift up on the outer part of the hard drive.
    • Pull the hard drive out.
  8. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: passo 8, imagem 1 %32 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: passo 8, imagem 2 %32
    • Remove the four Phillips #00 screws holding the HDD in the HDD cover.
    • The HDD should slide out after all screws are removed.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 4,433
