Introdução
If your keys are sticky, missing, or otherwise broken, the keyboard may need replaceing. The keyboard is alo a nessary part to remove if one needs to get to any internal components.
O que você precisa
Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
Slightly push up while lifting up on the power button panel to release the panel.
Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
Carefully (holding both sides of the keyboard), push up and lift slightly.
Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
Use the black spudger to lift the black latch holding the keyboard ribbon cable.
