Ir para o conteúdo principal
HP Prime Graphing Calculator G8X92A Button Panel Replacement
O que você precisa
  1. HP Prime Graphing Calculator G8X92A Button Panel Replacement, Battery: passo 1, imagem 1 %32 HP Prime Graphing Calculator G8X92A Button Panel Replacement, Battery: passo 1, imagem 2 %32
    • Power down the device.
    • Flip the device face side down so the back of the device is facing up.
  2. HP Prime Graphing Calculator G8X92A Button Panel Replacement: passo 2, imagem 1 %32 HP Prime Graphing Calculator G8X92A Button Panel Replacement: passo 2, imagem 2 %32 HP Prime Graphing Calculator G8X92A Button Panel Replacement: passo 2, imagem 3 %32
    • Using a Phillips #00 screwdriver, remove the two 4.5 mm screws securing the battery cover located at the bottom center of the device.
    • Remove the cover.
  3. HP Prime Graphing Calculator G8X92A Button Panel Replacement: passo 3, imagem 1 %32 HP Prime Graphing Calculator G8X92A Button Panel Replacement: passo 3, imagem 2 %32 HP Prime Graphing Calculator G8X92A Button Panel Replacement: passo 3, imagem 3 %32
    • Remove the battery.
  4. HP Prime Graphing Calculator G8X92A Button Panel Replacement, Button Panel: passo 4, imagem 1 %32 HP Prime Graphing Calculator G8X92A Button Panel Replacement, Button Panel: passo 4, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the four 4.5 mm screws securing the back panel to the device.
  5. HP Prime Graphing Calculator G8X92A Button Panel Replacement: passo 5, imagem 1 %32 HP Prime Graphing Calculator G8X92A Button Panel Replacement: passo 5, imagem 2 %32 HP Prime Graphing Calculator G8X92A Button Panel Replacement: passo 5, imagem 3 %32
    • Using a spudger, gently pry apart the front and back panels.
  6. HP Prime Graphing Calculator G8X92A Button Panel Replacement: passo 6, imagem 1 %32 HP Prime Graphing Calculator G8X92A Button Panel Replacement: passo 6, imagem 2 %32 HP Prime Graphing Calculator G8X92A Button Panel Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a Phillips #00 screwdriver, remove the eleven 3 mm screws securing the battery board/button panel located at the bottom half of the device.
    • Using a plastic opening tool, gently pry the retaining clip securing the ribbon cable to the top-left side of the board.
    • Using plastic tweezers, gently unplug the ribbon cable from the board.
  7. HP Prime Graphing Calculator G8X92A Button Panel Replacement: passo 7, imagem 1 %32 HP Prime Graphing Calculator G8X92A Button Panel Replacement: passo 7, imagem 2 %32 HP Prime Graphing Calculator G8X92A Button Panel Replacement: passo 7, imagem 3 %32
    • Using a plastic opening tool, gently pry upward on the battery board/button panel from the bottom to remove.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 1,085
