O que você precisa
Unplug the device from any energy sources.
Lift the top cover of the scanner.
Use a plastic opening tool to remove the plastic frame surrounding the glass.
With the top half of the printer separated, lift the upper section with the scanner glass away from the lower section of the printer.
