O que você precisa
Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
Remove the two T10 12mm Torx screws from the left side panel.
Set aside the printer body.
Remove the three T10 12 mm Torx screws from the back of control panel circuit board.
4 outras pessoas executaram este guia.
