Ir para o conteúdo principal
HP Photosmart Premium C309g Scanner Glass Replacement
O que você precisa
  1. HP Photosmart Premium C309g Scanner Glass  Replacement, Scanner Glass: passo 1, imagem 1 %32
    • Open the top of the printer. The printer should appear as shown.
  2. HP Photosmart Premium C309g Scanner Glass  Replacement: passo 2, imagem 1 %32 HP Photosmart Premium C309g Scanner Glass  Replacement: passo 2, imagem 2 %32
    • Use the blue plastic opening tool to pry the trim pieces all the way around the printer.
    • Loosen the pieces around the edges before pulling to remove from the printer.
    • Pull the (4) trim pieces off and set them aside.
  3. HP Photosmart Premium C309g Scanner Glass  Replacement: passo 3, imagem 1 %32 HP Photosmart Premium C309g Scanner Glass  Replacement: passo 3, imagem 2 %32
    • Using the blue plastic opening tool, pull from the middle and then slide back to remove the side panels.
    • The side trim pieces need to be removed before the front trim pieces.
  4. HP Photosmart Premium C309g Scanner Glass  Replacement: passo 4, imagem 1 %32
    • Using the T9 Torx Security screwdriver bit, unscrew the five 12mm screws shown.
  5. HP Photosmart Premium C309g Scanner Glass  Replacement: passo 5, imagem 1 %32
    • The scanner flap is attached by a clip that can be dislodged by pulling it gently away from the printer.
    • Keeping the scanner flap upright, slide it toward the unattached clip in order to dislodge the second clip.
    • Both clips will come unattached and you can set the scanner flap aside.
  6. HP Photosmart Premium C309g Scanner Glass  Replacement: passo 6, imagem 1 %32
    • Lift the scanner glass piece from the printer.
  7. HP Photosmart Premium C309g Scanner Glass  Replacement: passo 7, imagem 1 %32 HP Photosmart Premium C309g Scanner Glass  Replacement: passo 7, imagem 2 %32
    • The scanner glass is attached to the plastic piece with adhesive tape.
    • Pull off the glass and re-set new piece of glass.
Conclusão
Uma outra pessoa concluiu este guia.
Laura
Membro desde: 10/23/14
694 Reputação
Autoria de 3 guias
Equipe
Michigan Tech, Team 1-2, Lauer Fall 2014 Membro de Michigan Tech, Team 1-2, Lauer Fall 2014
MTU-LAUER-F14S1G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 755
