Ir para o conteúdo principal
HP Photosmart Premium C309g Printhead Replacement
  1. HP Photosmart Premium C309g Printhead Replacement, Printhead: passo 1, imagem 1 %32
    • Open the top of the printer as shown.
    • Locate the ink cartridges housed by the printhead.
  2. HP Photosmart Premium C309g Printhead Replacement: passo 2, imagem 1 %32 HP Photosmart Premium C309g Printhead Replacement: passo 2, imagem 2 %32
    • Remove each ink cartridge by pushing the tab and lifting the cartridge.
    • Set all 5 cartridges aside.
  3. HP Photosmart Premium C309g Printhead Replacement: passo 3, imagem 1 %32 HP Photosmart Premium C309g Printhead Replacement: passo 3, imagem 2 %32 HP Photosmart Premium C309g Printhead Replacement: passo 3, imagem 3 %32
    • Lift the lever located on the right side of the printhead.
  4. HP Photosmart Premium C309g Printhead Replacement: passo 4, imagem 1 %32 HP Photosmart Premium C309g Printhead Replacement: passo 4, imagem 2 %32
    • Lift the printhead and remove it.
Conclusão
10 outras pessoas executaram este guia.
Laura
Membro desde: 10/23/14
694 Reputação
Autoria de 3 guias
Equipe
Michigan Tech, Team 1-2, Lauer Fall 2014 Membro de Michigan Tech, Team 1-2, Lauer Fall 2014
MTU-LAUER-F14S1G2
Membros da 3
Autoria de 5 guias
Um comentário
Greetings:
I just replaced an empty black ink cartridge. The colors all print, but the new cartridge does not print. I have touched the cartridge and the ink seems wet and okay. Any other thoughts? I have taken the cartridge out and re-inserted it numerous times to no avail.
Thank you for any help you can give me.
Louann Dicus
dicus_6216 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 5,487
